Help!! Negative camber on 96 E320
Old Dec 1, 2008 | 12:56 PM
ampedbikes's Avatar
E-320
I recently purchased an 96 E320 from a friend of mine and it has the Eibach 2540.001 springs on 18" wheels.
The problem is that it has negative camber and wearing tires. I don't want to replace the tires every couple of months..
I spent the about 3 hours yesterday re-installing the original front springs and I don't like the look. So before I put the Eibach's back in is there a solution to the negative front camber?
The previous owner said it was at maximum adjustment.
Can this be fixed?
Old Dec 1, 2008 | 01:33 PM
ETP's Avatar
ETP
98 E320 99 E430 w/mods
camber issue
Not with the stock parts......Get K-mac units or lensolo links for the rear and mercedes camber bolts for the fronts.Speedybenz web site shows install of rear links if you want to see what is involved.... If you need the rears K-mac is located in Australia. Lensolo can be found at benzworld.org good luck
Old Dec 1, 2008 | 01:38 PM
ampedbikes's Avatar
E-320
Thx!.. The rear is fine, its just the front with problems.
Old Jan 19, 2009 | 08:46 AM
SL500_Now!'s Avatar
SL-500
Maybe you should go to China where you buy your junk to get it fixed. lol
