what is that black square next to trunk release button?
Old Jan 14, 2003 | 12:22 PM
btx's Avatar
btx
Mine doesn't have this, but I've seen them on some. They are to the left of the trunk release button. What is this for?
Old Jan 14, 2003 | 04:16 PM
Dema's Avatar
i535
I think it something to use a screw driver to be able to move a shifter if your batteries died. But I could be wrong.
Old Jan 14, 2003 | 05:59 PM
BenzE's Avatar
2006 E500 4matic Wagon
If you have Parktronic, it's shut-off switch is to the left of the trunk release, I think...
Dunno about the shift-lever release.
Old Jan 14, 2003 | 06:50 PM
btx's Avatar
btx
what is parktronic?
Old Jan 14, 2003 | 07:00 PM
BenzE's Avatar
Parktronic is an option that fits sensors in your front and rear bumpers and rigs them to an electronic signal inside the passenger cabin that alerts you with lights and an audible signal as you get closer to obstacles when parking. It is supposed to help you parallel park, avoid hitting carriages in supermarket parking lots, etc.
In my opinion, it's a silly thing.
You can read about it at MBUSA.com
Old Jan 15, 2003 | 02:01 PM
Air Marshall Eldritch's Avatar
John Deere
Parktronic is for the legally blind drivers, and the elderly.
Old Jan 15, 2003 | 05:03 PM
USFBulls's Avatar
2019 E53 Cab
Were you referring to the black square on the outside of the trunk next to the keyhole/release?
Old Jan 16, 2003 | 12:05 AM
dallasdriver's Avatar
99 e430 Green
On some its like a thing that goes green when you unlock the car and red when you lock the car. Its like an external key sensor I think. I have only used one w210 with this and it was like a 97.
Old Jan 16, 2003 | 11:42 AM
AWE's Avatar
AWE
I think the question was pertaining to the black square plastic beside the trunk release switch on the center console.
Old Jan 16, 2003 | 12:01 PM
Hank's Avatar
Folding mirror button.
Old Jan 16, 2003 | 12:20 PM
btx's Avatar
btx
Actually, I am referring to the the black square on the outside of the car, in the rear, to the left of the trunk keyhole/release button.
Old Jan 16, 2003 | 12:22 PM
btx's Avatar
btx
If you take a look at this thread, it has a pic of what I am talking about https://mbworld.org/forums/showthrea...threadid=27305
Old Jan 16, 2003 | 04:02 PM
rp718's Avatar
1996 E320
You press it, and a fully stocked wet bar appears in your truck when opened.
Old Jan 16, 2003 | 05:13 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
The trunk thingy is only found on the 1997 models. Here is a 1997 upgraded to look like the 2000+ models - even has phoney GPS antenna on roof:
Old Jan 16, 2003 | 05:53 PM
osiris667's Avatar
97 E420
Thumbs up The Little black square is...
On mine it is a little black square with a red and green light.
When I lock my doors, it will flash red, when i unlock, it will flash green. I have the same square on the driver side door, where the lock would be, and on the rear view mirror.
'97 E420 / Kleen'd
Old Jan 16, 2003 | 11:45 PM
AWE's Avatar
AWE
If I am not mistaken, those are infrared receivers.
It was only recently that the MB key used both IR and radio key controls. The radio opens the door locks while the IR opens the windows.
As in the new cars, you will need to point the key to that receiver on either of the driver and passenger door to open all the windows and sunroof.
The IR portion of the key also is what disengages the lock in the key tumbler to turn the ignition on.
Old Jan 19, 2003 | 08:27 PM
johnny's E320's Avatar
1998 E320 Sedan
I have the Answer!! With Photos to Prove it!!!
Upon close examination, I finally figured out the mystery to the little BLACK BOX next to my trunk keyhole! Observe below!<p> <p>
