Alignment
Old Dec 23, 2008 | 08:46 AM
MBE430!'s Avatar
E430
Alignment
Hi all,
After having my car for around a year and a half. I finally need an alignment.
Just wondering how much they usually cost. I also think I need to rotate my tires. How often should i do so?
Old Dec 23, 2008 | 09:07 AM
kstreufert's Avatar
2017 C300W4 2018 GLE350W4 2018 E400A
I try to rotate my tires every 5,000 miles. These cars require all 4 wheels to be aligned. Don't take it to your local tire store. The alignment needs to be don't by someone who really knows what they are doing. I would recommend taking it to a good independent mechanic or the dealer. The last time I had mine aligned it was around $200.
Old Dec 23, 2008 | 10:52 AM
lkchris's Avatar
'10 CL550, '12 GL550
Been hitting a lot of potholes and damaging suspension parts?
Are various suspension joints worn?
If not, you don't need an alignment.
If so, it's clear you need to go to a dealer, as no one else has Mercedes parts. There's no such thing as a "needed" alignment that doesn't involve replacment of parts.
Old Dec 23, 2008 | 03:17 PM
MBE430!'s Avatar
E430
nope pretty sure i need an alignment. I had my whole suspension system done 5 months ago. Everything was done.
Old Dec 23, 2008 | 04:40 PM
ohlord's Avatar
Several shops
all across the country have the new hunter align machine and can get camber eccentrics just as easily as the dealer for far lower cost.You need not go to the dealer,a hunter machine at a good indie shop will do just as good a job.
