w210 shocks
Old Jan 13, 2009 | 01:38 AM
stickygreen's Avatar
'97 E320
w210 shocks
Is there a shock available for our cars that is a bit firmer than the OEM Sachs, but not quite as firm as the Bilstein HD? I know Bilstein makes "comfort" line, but I haven't been able to find any online for the w210.
Old Jan 13, 2009 | 02:04 AM
ohlord's Avatar
SuperTouring
From www.autohausaz.com
If your shocks are 11 years old,you will enjoy these.
Raymonds diy r/r is on benzworld.org w210 diy section
Old Jan 13, 2009 | 02:19 AM
'97 E320
Are those oem shocks? Not a bad price...
I switched from oem to Bilstein HD's about 120k miles ago, and now that the fronts are starting to leak, I'd like to soften things up a bit.
Old Jan 13, 2009 | 11:40 AM
tirona's Avatar
1997 s320, 1997 e320
i;m still with the original factory shocks at 160k miles and don't feel the need yet to change the shocks, ride is still pretty good. the car runs no different than it did 6 years ago. i only changed the stabilizer links and lower ball joints when i thought the ride was getting a little worse and i was hearing a little clunk over bumps, but after that the ride is pretty comfortable and quiet.
Old Jan 13, 2009 | 07:30 PM
ohlord's Avatar
At 160K
you have been riding on old shocks so long you have adapted to the ride.New ones would amaze you with the new car ride quality.
Old Jan 13, 2009 | 09:49 PM
E420White's Avatar
1997 E420
Bilstein...
If memory serves, Bilstein makes three shocks for the 210. I've had Bilstein HD's, which greatly improved the ride, added more firmness, but the car still rides like a Benz.
The models were:
Bilstein OEM- soft, stock ride, designed for stock ride height
Bilstein HD - Heavy Duty, firmer ride, designed for stock ride height
Bistein Sport- Firmer ride, designed for cars that have been lowered, approx. more than 1 inch...
There are other brands, Boge, etc..
Old Jan 14, 2009 | 01:21 AM
'97 E320
Called Bilstein USA today...the only shocks they offer for a w210 are HD's and Sports, both with identical valving but hte Sports have a shorter body. I was also told that it is "normal" for Bilsteins to leak a little as they are just "keeping the seals lubricated." The rep said I should only worry once the shocks are leaving puddles. Sounds like BS, but they seem to be working okay for now.
When the time comes, will probably be going back to Sachs.
Old Jan 16, 2009 | 01:06 PM
skyrocket2's Avatar
Mercdes 1996 E320
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CFred%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshowes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I have a 1996 E-320 ELEGANCE Registered on 01-AUG-1996 I purchased it in 2001,
Engine No 104995-02-053680
Chassis No 210055-2A-195110 X
It came with sports suspension and I have always hated the ride I found it to hard, great for going round corners but still a hard ride,
I would like to replace it with a softer suspension I have looked around and come up with bilisteins fronts B362154 standard HD rears B362155 standard HD.
I do relies that the sports is lower by an 1” or more and will I have to change the springs or anything else for that matter any help would be appreciated
