Rough Running after MAF Clean
Replaced the timing cover seal over the weekend. Once I was done I decided to clean the MAF. Not having the sercurity torx I just did my best to spray the CRC MAF cleaner in both ends and let dry.
Well I had issues getting the car to start. Once it did start the idle was rough and then the CEL came on. mis cyl 1 and 3 and random mis-fire codes.
I'm assuming I screwed up the MAF as all plugs seem to be firing fine.
HELP.....
Try unplugging your MAF and you will quickly see if that is the reason. If you still have issues the MAF is fine. Only thing that will happen without the MAF connected is that the engine will go into limp mode.
You got the fluid into the intake,either let it run at idle till it smooths out or disconnect the battery and let the ecu reset itself.If the engine was running rough and after a few minutes settled down to normal idle and your only after affect is the cel,the battery disconnect will clear it or to avoid having to resync all you windows and steering wheel angle sensor and throttle position sensor,just get A $49 obd2 94169 scanner from harborfreight tools and erase the codes.
crc cleaner is meant for mafs,mafs can be cleaned if you do it properly by removing the insert.Security torx bits are sold at most auto parts stores for about 7bucks a set.use them next time.
diy maf cleaning is on benzworld.org w210 section.
So is it running fine now?
I'll try to dis=connect the battery after work and see what happens.
