First MB Brake Job
I've been searching the forums and here's what I think I need:
1. A torx bit to remove the calipers
- what size will I need? T40?
- do I want to remove the bolts or simply loosen them? I've seen different recommendations in different posts.
- what brands do people like?
4. brake paste
5. Anything else?
Random questions:
- Do I need a caliper tool to compress the piston or can I use a C-clamp?
- Are there 2 pistons on the rear calipers? If so, is there any special technique for compressing them?
- People seem to recommend autohauz for parts. Are there any other places I should consider? Any reason not to go to the local Carquest or Autozone for pads?
Thanks!
There are 3 wear sensors (both fronts/one rear) if all need to be replaced.
Will prob need hunk of 2 x 4 and 3lb hammer if replacing rotors too.
Work safe,use jacking points,jack stands,chock wheels,etc.
have fun
2. I needed a 7mm hex bit to remove the calipers. Sears had a small set of bits on sale for $20 and I picked up a cheap compression tool for $10.
3. I didn't bother with brake paste
4. Pay attention to how the caliper spring is installed. I put it back incorrectly on the first side and had to pull the wheel off again to fix it.
5. It looks like the rear pads are going to need replacing soon. On my car, there is only 1 rear sensor (on the passenger side).
6. I asked about loosening -vs- removing the caliper bolts based on info I read in another thread. I'm not sure why they recommended not removing the bolts unless you plan on lubricating them. They just slip into a rubber boot to keep them protected from dirt and salt.
So, 2.5 hours and $100 to change the front pads (and rotate the tires).
x2 on the caliper spring installation. pay attention!
