please help! 98 e430 projector fog lights
hi, i have a 98 e430. i have purchased a pair of projector fog lights and i am having a problem with installion. i have tried to connect them and also i spliced and twsted the old and new wires together but still no luck. there are two wires on the lights white and black, and two wires from the factory connector brown and black. thanks in advance for your support.
'01 W210 E320 CDI
What are you trying to do? Replace the existing fogs or adding extra fogs? When replacing you might get a defective-lamp-warning, when adding you may need to wire it up with a relay. I'm sure others will jump in on this...
'01 W210 E320 CDI
Projector as in HID's?! That makes no sense cuz the light intensity gets reflected and scattered dangerously around by the fog. No one thinks you're cool running with fogs lights on anyways. I would stick to the OEM fogs...
