Drivers Side Widow Problem.????
Old Feb 8, 2003 | 07:35 AM
STEVE 280 UK's Avatar
W210,E280 ADVANTGUARDE
Exclamation Drivers Side Widow Problem.????
HI
I AM NEW TO THIS FORUM,I OWN A 1996 W210 ,E280.HAVE OWNED FOR 2 YEARS ,NO PROBLEM. BUT NOW DRIVERS WINDOW WILL NOT GO ALL THE WAY DOWN,IT USED TO GO DOWN FLUSH TO WINDOW SILL.BUT NOW IT STOPS ABOUT 4 INCHES ABOVE WINDOW SILL,ALL THE OTHER WINDOWS WORK FINE.ANYONE HAVE ANY IDEA WHATS WRONG,
THANKS
Old Feb 8, 2003 | 09:25 AM
synchrocnc's Avatar
SL500 M119 1998
Hi There ,
Welcome , I live in the stourbridge area , small world
I would take the door trim off and have a look in case anything is obviously obstructing it , Its quite easy to get the panel off :-
3 large screws , under the door pull trim , under the gromet in the middle of the door and under the SRS badge .
remove the door latch cover
then carefully pull the trim off from the bottom and release the top by pushing the panel upwards .
Cheers Alan
