Oxidized headlights
Old May 16, 2009 | 12:56 AM
j944's Avatar
2002 CLK430
Oxidized headlights
I was venting to a friend about the haze on my headlight lenses. He mentioned using brake fluid to remove it.
I am very pleased w/ the results and had to share. I masked off the painted area's surrounding the lens and applied a couple of coats of brake fluid and used my buffing wheel. I applied it on the left lenses
Thank you
John
Old May 16, 2009 | 01:37 PM
tirona's Avatar
1997 s320, 1997 e320
thank you for posting your results john. good to know, mine are not in their best shape, so i;m gonna give it a try. too lazy to do all the wet-sanding, polishing etc. hopefully the brake cleaner will do the trick.
Old May 16, 2009 | 01:44 PM
raymond g-'s Avatar
99 E320
stranger solutions have been tried and used. see this one...oven cleaner
Old May 16, 2009 | 02:37 PM
ConeKillerSTI's Avatar
E320 4matic Wagon (w210)
you might want to try and get some light buffing compound and buff them. that should clean them right up.
Old May 17, 2009 | 03:47 AM
ohlord's Avatar
I don't see
much or any improvement.
Here is the result of my diy method performed on a sadder set of lenses than your lamented ones.
Brake fluid,oven cleaner,paint thinner,only remove the old yellow hazed clear coat uv treatment on the oem lens. Wet sand ,Polish and buff is the only way to return them to better than new condition.Watch out if you use cotton buffing pad and a rotary buffer.If you don't know what you are doing you can overheat the lens and heat check it
coke works very nicely on chrome when buffed on with a piece of aluminum
Old May 17, 2009 | 10:06 AM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Buy the 3 inch orbital buffer from Griots Garage for 79$ and then get the lens polishing paste from Pep Boys. The buffer saves time and finger ache and does a great job. The specially formulated lens polishing paste is designed for these plastic lens and will not deep scratch your lens covers. Start with this first and if not successful then try the sanding and polishing route as Oh Lord has mentioned. These lens are not cheap and I would seriously hestitate to put oven cleaner or brake fluid and or other such crap on them. It will mess with the plastic and seriously soften it to the point of long term damage where you will be replacing them next time around or sooner. Don't weaken the plastic with this junk.
