Selector lurchs forward
Old May 31, 2009 | 11:40 AM
ncd20's Avatar
2001 E320 Avant turbo diesel
I am having difficulty working out where this problem is actually comming from
The rubber washers on the selector top and bottom?
The Tranny Mounts
The Engine Mounts
Drive Shaft
I was reading this url:
http://www.peachparts.com/shopforum/...p/t-45196.html
I performed his test off turning the wheels completly to each directiion and gave her some acceleration the engie moves about 2-3" each directiion should it move at all??
Old May 31, 2009 | 12:17 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
The engine should not move that much. First, check your engine mounts and replace if they are bad.
Old May 31, 2009 | 12:21 PM
TMAllison's Avatar
09' E320
Engine mounts can be measured to determine if they are collapsed or not. New there is 17mm space from top most rim to the top of the mount. They are considered collapsed at 13mm.
Use a feeler gauge to measure. I used a socket whose OD was 13mm.
If the gear selector moves or vibrates the shifter bushing beneath the car is prob worn. Mine is Green.
Old May 31, 2009 | 12:28 PM
ncd20's Avatar
ok tnx for the replys chaps, I will check that way TMAllision sounds more exacting .. I think mis interprited hes method anyway he was talking about from inside and I think he was in gear too i was Neutral and doing it engine side..
The shifter does not vribrate not that Ive noticed before anyhow, only when you TRY pull away like steve mcqueen does it move.
Old Jun 4, 2009 | 10:07 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
If the gear selector moves or vibrates the shifter bushing beneath the car is prob worn. Mine is Green.[/QUOTE]
AMG E55, E430 and E320 all use same bushing which is green. It can be accessed from beneath by reaching on top of the tranny for the single arm and removing the clip holding the rod from the tranny into the lower rod arm from the shifter. It is easiest to remove the shifter assembly and from the inside of the car lift the rod up gently through the floor cut out and remove the clip. The green bushing will be immediately visible at the end of the lower shifter arm on the shifter assembly. A couple of bucks at the stealership. Whole job should take 30 minutes or so. A 2 on the 1-5 scale of DIY jobs.
Old Jun 6, 2009 | 08:17 AM
ncd20's Avatar
hrm blasted down a road in anger after our multi-coloured friends pulled me over for no reason.. took a corner at fair speed... and then sudenly the car starts to vibrate like MAF gone wrong ... atfirst I thought it was a tyre deflating so I put it in Park inspected all round nothing, then I though hmm MAF so soon??... got back in and vibrations gone ... weird hey??
Old Jun 9, 2009 | 10:32 PM
ejsheltra's Avatar
Something sounds still amiss. Problems just don't go away IMexperience! Sounds like something is broke and just slipped back in position but is still broke. Keep looking.
Old Jun 14, 2009 | 12:32 PM
ncd20's Avatar
I nearly forgot about this thread.. I took the car to quickfit and asked them to inspect running gear, egnine mounts and tranny mounts the guy said they all seem ok to him ... very slight play on the front left engine mount ... which is where allot of doogyness is comming from at the moment.
So I suppose I Will be doing the bush's on the selector and a engine mount at the same time I do my Trany service .. which seems to be becoming a never ending endevor.. heh contemplating getting a conductor plate now .. just incase lol
