gear change speed
Old Jun 4, 2009 | 08:40 AM
ncd20's Avatar
2001 E320 Avant turbo diesel
gear change speed
I have always thought to my self the tiptronic is very late to react .. is this a fault, or is it just the transmisions normal nature.. can anything be done to improve it?
Old Jun 4, 2009 | 10:33 AM
99BENZe320's Avatar
1999 e320
mine does the same thing. if you are under full throttle it will take it a second or two to change gears because there is no clutch but if your not under full throttle and shift around say 3000 rpms it will shift right away
Old Jun 4, 2009 | 02:55 PM
alpinestar_k's Avatar
2001 E430 Sport; 2000 E320 (RIP 9/9/09); 1991 300SE
Mine's late too, but you learn to adapt I guess...have you tried the ECU reset after the drive-by-wire has "learned" your "regular driving" habits?
I tend to forget the difference it makes if I don't do it for awhile. I guess it won't necessarily help the tip's reaction time, but you might notice a difference in throttle response.
Old Jun 4, 2009 | 08:04 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Checked with dealer a year back, no fix for slow shifts other than ecu reset which will change rpm shift points alone. Best wishes.
Old Jun 4, 2009 | 10:09 PM
ohlord's Avatar
Dealer don't know jack
Do a tcu reset and it will up the shift points and modulation pressure.Wakes up the trans like a quick kick in the ***. Gas is what I meant to say
Old Jun 4, 2009 | 10:28 PM
ejsheltra's Avatar
Oh Lord or Aanybody, Do you know if the sensitivity to the tiptronic can be adjusted? I pull left all the way to downshift and just nudge right to upshift. It feels off center. Thoughts oh wise one?
