M112 240/280/320 oil filter housing retainer bolt size
Old Jun 14, 2009 | 04:02 PM
stevesey's Avatar
98 C240 Sport
Seal's leaking a little oil.
Anyone know what size part 41 here is?
I want to replace the seal (part 35) so need to get a big socket/box spanner to undo this bolt.
Also anyone know the torque wrench setting for doing it back up?
Old Jun 15, 2009 | 05:16 PM
stevesey's Avatar
98 C240 Sport
bump
Old Jun 15, 2009 | 08:08 PM
ohlord's Avatar
When you pull
the bolt record what number is stamped on it and then measure diameter.
You can then look it up on
http://www.engineershandbook.com/Tab...ictapdrill.htm
to find out the metric number and then look it up on the torque chart for specs.
Post when derived.
or you can go to lowes and they can put it up to their bolt gauge and tell you what size it is and then look up the torque.
Most of those big ones are about 60-80nm but check anyway.
