Partial Instrument Cluster/Guage Failure
Old Jun 19, 2009 | 10:28 PM
severecaraddict's Avatar
2004 Oxford Green BMW 530i SMG
I had included this in another thread I posted but had no luck figuring out the issue, so I thought I'd give it another go while I have some free time to work on the car. About a month ago my '96 E300 experienced an issue where it didn't want to to start. The red/green indicator lights on the rearview mirror flashed and the car simply wouldn't start.
After several seconds of spinning the car over the tachometer, fuel gauge, and temperature hand quit moving. The starting problem resolved itself and on a hunch from another board member; I replaced the K40 relay with a new one from the dealer but with no success. Below I've posted a video of what I'm talking about and as shown during this video the ETS and ABS lights come on. I'm more concerned with the electrical issue involving the gauges. I've moved the car maybe 50 feet since putting in the new K40 relay, so I'm not sure if that resolved the abs/ets lights. The CEL is on during this video but that was due to a glow-plug error from when it wouldn't start before. I've sine cleared the code. Any input is greatly appreciated.
http://s235.photobucket.com/player.s...fs=1&os=1&ap=1
Old Jun 19, 2009 | 10:57 PM
ohlord's Avatar
So it runs
and the code is stored in the pending section of your obd2.Record the code and post it.
Have you checked the fuse to the cluster and the ribbon connection in the cluster?
Keep us posted AND SOMEONE WILL FIGGER IT OUT.
seems like a good puzzle hey.
Old Jun 19, 2009 | 11:03 PM
It does run now. I haven't had that issue since leaving the key in the 'on' position for about an hour one day. As for the code, it was a glow-plug related one that I doubt is related to the cluster, but I can try to retrieve it again. The cluster failed before the the CEL came on.
Where's the ribbon connection you mentioned above and where's the best way to access it? I talked a friend who's owned a Benz or two in the past and he said there might be a reset button for the cluster? No clue but I'm willing to try anything.
Old Jun 19, 2009 | 11:38 PM
ohlord's Avatar
No reset button
but you can pull the cluster and check the connections. And also(I hardly ever recommend this work around)You can try the so called reset by disconnecting the battery(key out when you do this) and stepping on the brake pedal for a minute to remove any residual charge in the system. When you hook it up again
comm will be reestablished with the cluster hopefully.
You will need to resync your windows and such----procedure for that is in the manual or up in the diy stickies that Greg built.
Hope it at least sets you down a path towards an odd set of symptoms.
