Will 00 W210 Drivers Seat fit a 01 ?
Old Jul 13, 2009 | 05:09 PM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Question Will 00 W210 Drivers Seat fit a 01 ?
The leather on my driver’s side seat is damaged and I have been able to locate a seat from 2000 W210. Can someone kindly confirm if the seat from a 00 will fit a 01? I will probably end up replacing the whole seat although only the bottom cushion area is damaged.
Also – Can someone point me in the direction to get instructions on swapping the seat?
Cheers
Old Jul 13, 2009 | 05:54 PM
Anatoli's Avatar
E500 estate
Yes, that are the same seats so the seat from the 2000 will fit to your 01.
Old Jul 14, 2009 | 01:26 AM
raymond g-'s Avatar
99 E320
brit -
nearly a no brainer.
there is a plastic cover which routes the seat belt...down low near the seat
pivot. single bolt. remove and set aside.
each of the 2 rail has single bolt into the floor. slide fully rear. remove front
bolts.
slide fully forward. at the end of each rail is a plastic cover which inserts
into, and lock onto the rail. slide off. remove bolts.
unplug ganged electrical plugs from beneath the front of the seats. note
carefully which is up, as I recall the 'big' one can be accidentally plugged
in backwards.
tilt and carefully maneuver the chair out of the car.
10-15 mins...but hell, who's counting? be methodical and careful.
