Help with gear selector
Old Jul 24, 2009 | 02:53 AM
watut's Avatar
1995 E320 Cabriolet
My friend just purchased a 97 E320 on the past weekend and it goes into P-R-N-D with no problems and drove it 1000 km with out a hiccup. The problem is the actual gear selector won't physically move into 4-3-2-1. What do you guys think is the problem? Anyone have this before?
Old Jul 24, 2009 | 03:21 AM
ohlord's Avatar
Shift module
or shifter bushing is not allowing the change over from one mode to the other.
Check the shifter bushing first.If it won't disengage the trans won't go into electronic mode.
If it's not the bushing the module is bad('water damage in most cases)
I can get used warrantied units shipped cheap and easy diy to install.
Old Jul 26, 2009 | 03:40 AM
watut's Avatar
1995 E320 Cabriolet
Do you have a pic of the bushing? the shifter is hard, it physically won't move over from D to 4
Old Jul 27, 2009 | 06:33 PM
watut's Avatar
1995 E320 Cabriolet
Does anyone know where the TCM is?
Old Jul 27, 2009 | 07:26 PM
ohlord's Avatar
Did you check the green bushing located
at the bottom of the shift module?
Seems like you module is bad. I have replacememnts. warranty, shipped.
Old Jul 28, 2009 | 11:22 PM
watut's Avatar
1995 E320 Cabriolet
I tried pm'ing you but your pm box is full...Can you pm me a price to Calgary AB...T2A 5Z8? Are they under the shifter? hard to change? Do you have a pic of it?
Old Jul 29, 2009 | 12:27 AM
ohlord's Avatar
Emptied a ton of
mail box. Send again.
diy replacement is on www.benzworld.org w210 diy section. Not hard to do.
Yes i can ship as gift.
