Tailights!!
Old Jul 30, 2009 | 11:18 PM
Euro92's Avatar
E320
Tailights!!
hey guys i went to get my foglights repaired today. One was cracked and the others frame was broken. Anyways everything was fine except the tailight in the back, when i would hit the brake, sometimes wouldn't turn home. Anyways i took the car home. My pops tried to fix it and a spark went off. Now when i turn on the headlights, the right tailights dont turn on at all!!
I went to buy a new Bulb... still nothing... Also right when that happened the front Lowbeam headlight on the right side as well, went out!!
I need some advice...what could be the problem and what can i do?
thanks guys
Old Jul 31, 2009 | 12:28 AM
raymond g-'s Avatar
99 E320
sparking is a good hint: check fuse panel on left end of dash (for euro
versions, it may be on right end of dash). you can't get to this until
you open the door. pry off 4x6" cover. check for blown fuse. bulb(s)
may have blown as well so dbl check.
