wipers do not work
Old Aug 1, 2009 | 12:42 PM
tootyte36's Avatar
1998 e320
Angry wipers do not work
i just got my e320 w210 it's a 1998 v-6 and the dealer told me the wiper motor need to be replaced so i got a new wiper motor and replaced it it still dose not work could it be a relay /fuse??????? any info will help don't want the dealer to fix it the want like $900.00: smash:
Old Aug 1, 2009 | 01:20 PM
ohlord's Avatar
Why buy
a car with parts not working?
Wiper stalk could be bad,wiper relay located by ecu could be bad,wires could be shorted. You are going to need to take it to someone and pay something.Find an indie mb shop it will be lots cheaper than the dealer.
Old Aug 1, 2009 | 02:45 PM
tootyte36's Avatar
1998 e320
wiper motor
what is a stalk is it what hold the wiper motor or stalk as in wiper motor switch inside the car
Old Aug 1, 2009 | 03:24 PM
ohlord's Avatar
the stalk
that operates the switch on the steering column.
www.benzworld w210 diy section has procedures to repair.
Have you triedputting voltage to the motor and seeing if you can narrow down the issue?
Old Aug 2, 2009 | 07:35 AM
tootyte36's Avatar
1998 e320
how do u put voltage to the motor?
Old Aug 2, 2009 | 09:36 AM
tootyte36's Avatar
1998 e320
Angry blower motor
so i got this 1999 200.000 mi e320 awd v-6 for $3500 cash was that a good deal the blower motor needs to be fixed and the wipers don't work,also the blower motor was removed when i got the car i have a the parts to install it back i put a new regulator on and got the blower motor to work is there any diy info on how to put it back together i live in FL and it's hot
Old Aug 2, 2009 | 11:27 AM
ohlord's Avatar
www.benzworld.org
w210 diy section a/c blower regulator diy.
Old Aug 9, 2009 | 07:57 AM
tootyte36's Avatar
1998 e320
So i did some work on the benz changed the 12 spark plugs dam.so i did some test on the wiper motor and when u turn the wipers on you can hear and feel a click in one of the releys does that mean it needs a new one or is the switch is bad i dont think the wiper motor is bad should i return the new one
Old Aug 27, 2009 | 05:27 PM
noddy2003's Avatar
e320
same problem, i changed the relay but still same problem. I suspect it could be the stalk
Old Sep 6, 2009 | 02:20 PM
tootyte36's Avatar
1998 e320
do u know or have read a post with diy info on re sotering some wiresi saw a post that had that info but can't find it on that post they talk about some wire not making contact and there is some re sotering to do to get the wiper to work i'm almost sure thats whats wrong.The stalk is sending power to the relay cuz when u turn it on it clicksthe power is not making it past the that pointfrom the relay to wiper motori swaped some of the relays around andi am going to try to pull out the box or fues that holds the relay and cheack for that or some thing like it
