no more body roll
Thanks for helping me make this $1200 decision. ($800 + 400 labor).
MarkO
Before you spent all that money, at least try this first.
Inflate you tires (especially the front) to at least 38psi.
Try again your car and see how you like it during cornering.
MB recommends only 33psi front for "normal" driving.
Some of the preceived "body roll" might be caused by the outside front tires scrubbing the outside shoulder.
I personally uses 38psi all around which I feel improves significantly the response/cornering behavior of the car compared to the 33fr/35rr setting.
Actually Vic is running H&R's with Bilstein shocks. And our webmaster mr. v is using this setup up H&R's and Koni. Either one of these setups if you do decide to have this done on your car will give you very less body roll and the handling much better! Although it will also give you a firmer ride. Hope this helps.
There is a sticker inside the driver door of my E55 that mandates 41 psi front / 48 psi rear in the Dunlop 9000s. With the pressure at 38 front and rear, there is marked instability at speeds over 115 mph.
They also said a E55 pulled 1g on a course in Europe so why would I want to upgrade the suspension anyway. I just want to feel the G's.
MarkO
bkc
MarkO
19's are big *** wheels. depending on what brand of tire you get the ride stiffness will vary. but stepping up from 18-19 will certainly make the ride a little harsher. combine that with the koni/H&R set-up and you will certainly have a significant degradation in ride comfort. it all depends on your preference. i ran coilovers and 17's on an A4 1.8t and i loved the kidney jarring ride.
41 psi front/48 psi rear is going to wear the center of the tires and it's going to happen pretty quickly if you maintain those pressures. Somewhere around 34 psi to 36 psi is optimal for everday driving providing more rubber contact area to the asphalt.
How do you account for AMG telling us that 41/48 is the correct pressure? Is AMG in cahoots with Michelin and Dunlop, helping them sell more tires? It is certainly possible. It is also possible that the soft compound in the Z-rated tires will suffer from the excess heat generated by running the tires soft.
Maybe one of us should ask Luke.
35psi front/ 35 psi rear works for me without any shimmy or drifting even at 145 (front windows open). Most modern cars will do 100 without any issue of stability, it's even more of a non event in a E55. If 41/48 makes you feel comfortable that's ok, because the only times I will use those higher pressures are: 1. If I am going to be a considerable distance from home (say 200+ miles) 2. On a racetrack etc. where most likely I will be heating up those tires pretty well. I have learned this from previous experience with my M5 which recommended similiar tire pressures and it devoured the tires in 7-8 months.
Most forum members use somewhere between 34-38 psi (this was a post last year).
I drive my car depending on road conditions and it is impossible to do 150 everyday in a traffic tieup.
When you run 35 psi cold, what is the hot pressure?
I get to drive on straight freeway with light traffic at least a few of times a week. I don't see 150 infrequently. Don't tell my wife.
