97 E320
Old Aug 10, 2009 | 12:26 AM
LeftLane911's Avatar
1997 E320
97 E320
OK, so I've looked on here and can't find what the remote sensors are called on the driver's side and the trunk, I live in AZ and the sun has done its damage to them. Would anyone know what/where to find these little red and green gizmos? Or point me in the right direction at least.
thanks in advance.
Old Aug 10, 2009 | 06:49 PM
TMAllison's Avatar
09' E320
You will probably find they are integral to each component.
Might try polishing them with 2000 grit followed by 3000 grit wet dry sand paper and a buffing wheel and/or changing the battery in your remote if its not responding as it should.
Old Aug 16, 2009 | 10:23 PM
E-420's Avatar
97 E-420
your looking at $200 +/- each for the sensor assemblies, better off either polishing them or if there toast, file off the exisitng plastic and replace it with a clear plastic cover using MEK to solvent weld the new cover on. That's what I did.
