Odometer light dim in 1999 E320
Old Aug 17, 2009 | 09:30 PM
99e320sam's Avatar
'99 E320
Hi
I noticed that my odometer light is dim, however the clock and temp light are bright and perfect.
Apparently I had removed the underside cover to r&r a temp sensor on the evaporator and ever since the light went dim on the odometer.
I wonder if I had accidently touched or did something.
Any thoughts?
Thanks for any help.
Sam
<!-- / message -->
Old Aug 19, 2009 | 08:05 AM
martz's Avatar
German
I had the same issue, but it was my clock that went dim. You most likely have the same issue I had , a burnt peanut bulb.
I simply pulled and replaced the bulb in the back of the cluster that had burnt out. The cluster board will tell you exactly what wattage to use.
Old Aug 19, 2009 | 09:56 AM
kyosuke's Avatar
1999 e320 ,2006 AMG S55
how do i get back there to the bulb ? my clock is dim too -__-
Old Aug 19, 2009 | 10:42 AM
martz's Avatar
German
http://cgi.ebay.com/ebaymotors/MERCE...motiveQ5fTools
others have improvised by using wire hangers
Old Nov 27, 2010 | 06:49 PM
frossi's Avatar
1999 e320 mercedes
Clock light is very dim
I need instructions on how to check/replace the clock light on e320 1999 model. The light is very dim and all other panel lights are of the proper intensity. Thanks with regards, Frank Rossi email: frossi@burlingtontelecom.net
Old Nov 27, 2010 | 09:39 PM
ohlord's Avatar
Pull the dash
cluster with the dash hooks remove bulb replace with like bulb from dealer part dept.
cheaper then paying shipping online for just one bulb
