Seat Adjustments and Power Windows
Old Aug 18, 2009 | 02:30 PM
climdis's Avatar
E 430 99
I searched the forume and could not find any specific information on the cause of the Seat Adjustment and power window failure for both the driver and passanger side. The driver's side stoped first with both the window and seat adj. not working then the passanger a day or so later seat adj and window as well.
Also, my SRS light has been on for the majority of the time eversince I bought the car 6 months ago.
Thank you for any info you might pitch in,
Clint
Old Sep 3, 2009 | 11:52 AM
climdis's Avatar
E 430 99
No luck
I tried to unplug the battery cables for a while and found out that that fixes the problem for about a day or so until the power functions on both driver and passanger side still don't work...
plese any info would be aprreciated..
thanks
Clint
Old Sep 3, 2009 | 05:06 PM
Wadster's Avatar
'09 CLK550 & 2012 E350
So pulling the power briefly resets the power seats? Or was it the temporary fix for the airbag warning lights?
Old Sep 16, 2009 | 01:27 PM
climdis's Avatar
E 430 99
Pulling the power off briefly resets the power window and seat adjustments controls..That will work for about a couple of hours.
What do u think?
Old Sep 17, 2009 | 01:46 PM
SnowCub's Avatar
2013 S350, 2021 GLS450, 2003 SLK32
I had the power window, mirror and seat controls on the driver's side stop working in my E300 and it turned out to be a failure of the CAN BUS controller in the right rear door. Check your CAN bus system for faults. My local guru diagnosed and fixed it in a couple of hours. ~$300 fix.
