How to remove instrument cluster on w210 sw
E200K
Hi johnmumie,
If you read my procedure above you will probably be able to get your instrument cluster out and disconnect it - make sure that your key/transponder is not in the ignition though. If your steering is not adjustable (via the lever immediately underneath the wheel) then you might have to manouvre (maybe even change the angle/position) the released cluster out from between the steering wheel and aperture towards the door perhaps by turning the wheel as you move the cluster to the side.
This is the link to give you some more pointers on your cluster removal:
http://www.benzworld.org/forums/w210...ml#post2606869
There is also a pdf on this website the link to which I have copied and pasted so that you can follow the instructions to potentially rectify your LED problem:
http://www.benzworld.org/forums/w210...splay-fix.html
Hope this helps.
Kev
Hope this helps.
Kev
