E 320 transmission problems 99
Old Aug 30, 2009 | 04:47 PM
muneca's Avatar
mercedez e 320 99
Hi
I have an e
320 of 99, this presented problems in the transmission.
At the start it is constantly in second (2nd) and does not allow gear changes, so that
made a diagnosis directly to mercedes benz. need to replace (tranny valve body). You install it again.
finally prove, once again displayed the same problem, does not turn off the check engine does not change the gears, turns in second.
I need advice with this dilemma, since it changes all that diagnosed the mb. change the module where they come from the transmission solenoids.
the filter.
9 liters new transmission fluid.
The tranny valve body.
I am at the expectation of help and suggestions.
Sincerely
Muneca
Old Aug 30, 2009 | 06:09 PM
muneca's Avatar
mercedez e 320 99
when conect the car on the computer this is the codes 715 that show me. ill chek online, the answer that i found was a problem with the speed sensor.
Can somebody help me with this pls????
