front and rear camber adjustments
I have searched the archives for vendors for these parts which resulted in speedybenz and lensolo rear camber arms. I have e-mailed them with no response. Are there any other options or vendors still around for these camber adjustment parts? Front and rear needed. Any help would be greatly appreciated.
2003 S210 3.8L Brabus wagon
Try Kmac if Lensolo is not responding. The two you mentioned do it as a side line hobby and not fulltime. I have the Lensolo and waited a little over two months from placing the order til receiving. They are a nicely designed unit. Kmacs are eccentric camber bolts for the rear. Camber adjustment for the front is already available. It is just the rear you need to change out.
Depending on the year of your car, if it is early build, replaced camber strut arms may just be enough. I believe that the eccentric bushing has been updated. There was a different part number when I replaced my original units that came with the car. My vehicle was a '97 MY. The Lensolo arms are sweet if you can get them. Worth it!
