Refrigerant leak in cabin?
Old Oct 11, 2009 | 09:09 AM
cbeebe's Avatar
My wife was preparing to drive my 98 E430 a couple of days ago and, upon opening the door, told me that there was "smoke" in the cabin. This was before she even started the car.
I immediately investigated and could find no smoke but did find a type of a fog that dissipated very quickly with a chemical smell. Certainly not electrical or "hot" smelling. I checked everything out and could not recreate.
Yesterday, when I was driving, I got a small blast of "fog" out of the dash vents, then the AC slowly started loosing effectiveness. The onboard diagnosis indicates that refrigerant pressure is slightly low at 5 bar.
I'm assuming this is a refigerant leak and am hoping that there is something other than the evaporator that might cause refrigerant to get into the AC vents. Any ideas or experience?
Old Oct 11, 2009 | 09:47 AM
ohlord's Avatar
Get the car
to an a/c shop and have them sniff it with an electronic sniffer.
Turn off the e/c button so the compressor is not running, You do not want to breathe the r134a,so open the windows,
Old Oct 11, 2009 | 10:45 AM
cbeebe's Avatar
Originally Posted by ohlord
Get the car to an a/c shop and have them sniff it with an electronic sniffer.
I will do...was just trying to figure out if it could be anything OTHER than the evaporator...
Old Oct 11, 2009 | 12:26 PM
ohlord's Avatar
should be is it r134a ,first.
Rule that out.If it were a leak of r134a you should be covered in oil and smeel it.Big enough to fog the car it would all leak out shortly and you would have no a/c at all today when set on low.
Coolant leak,oil on exhaust,trans fluid leak ,all are suspect after you rule out the one that can kill you by suffocation.
