can someone take a pic of the fuse box?
Old Oct 14, 2009 | 02:21 AM
stunna202's Avatar
02 c240
i just checked my fuse box and its missing some fuses...i drive a 98 e320 4 matic...if it matters
i just wanna know what im missing....thanks guys
also i cannot find the battery?
Old Oct 14, 2009 | 03:41 AM
ohlord's Avatar
under the rear
seat passenger side.
If everything is working certain fuses will be missing for options your car is not equipped with.
Fuse chart is usually in a holder next to the battery with the main fuse box that you have not seen yet.
if you don't have one you can find a pdf on www.benzworld.org w210 diy section.
If you need an owners manual a file for that is also over there.
change your transmission fluid and filter mb spec 722.6 fluid.You are due
