2001 E-430 Replacing Broken Rear Window Regulator, Do I need to unplug battery?
Old Oct 23, 2009 | 12:46 AM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
2001 E-430
I am replacing broken Rear Window Regulator, Do I need to unplug battery? The reason I am asking this question is that I noticed that I have airbag in my 2001 W210 rear doors. I just want to make sure I will not activate air bag while working on Window Regulator.
Please some one can give me feed back.
Old Oct 23, 2009 | 07:22 AM
ohlord's Avatar
Yes
unplug it.First for safety second if you disconnect the ab for any reason you won't need to have it reset.
Just resync all the windows and sunroof and your steering wheel angle sensor when done.
Old Oct 24, 2009 | 02:49 AM
hadam's Avatar
How to synch windows/sun roof and steering wheel angle sensor
Ohlord thanks for the feed back. I am sorry can you point me to post that describe how to re synch the windows/sun roof and steearing wheel angle sensor. Thank.
Old Oct 24, 2009 | 03:22 AM
ohlord's Avatar
The owners manual
or the reset diy in the battery area on www.benzworld.org w210 forum diy section at the top of the page.
Easy
make sure you have your radio code if you need to re enter it.
You get that from any mb dealer or might be on a card in your radio book.
Old Oct 24, 2009 | 10:32 AM
Quadcammer's Avatar
96 and 08 911 turbos
eh, I don't bother when I remove the door panels.
Old Oct 25, 2009 | 01:13 AM
Red66GT's Avatar
2008 S63 AMG Designo Edition
When I replaced my rear window regulator I did not disconnect the battery and I had no problems. However, as ohlord posted it's probably wiser to do so because the window and steering re-synch only takes a minute or 2..........
Old Nov 1, 2009 | 02:08 AM
99210's Avatar
1999 e320
no///just have key out
