04 e320 wagon wont start!
04 e320 wagon, 94 e500
HELP!! I HAVE A CODE READER ON THE WAY BUT FOR NOW ANY IDEAS?
SYMPTOMS-CARS CRANKS JUST FINE, BOTH CAT COVERTERS DEVELOPED WELD CRACKS SO THE CAR HAS BEEN RUNNING VERY ROUGH BUT THAT SHOULD NOT HAVE ANYTHING TO DO WITH A NO START. ALL FUSES CHECKED OUT. BOUGHT NEW FUEL PUMP RELAY (WISHFUL BUT STUPID THINKING SO WASTED $57 BUCKS). BUT HONESTLY DO NOT KNOW WHERE TO REPLACE AS THE NUMBER ON THE RELAY I BOUGHT IS DIFF. FROM ALL RELAYS ON FUSE /RELAY PANELS. 002-542-72-19 ON NEW RELAY.
NO SMELL OF ANY FUEL WHEN TRYING TO START. MAKES ME THINK NO FUEL GETTING TO INJECTORS. WANTED TO CHECK FUEL FILTER WHICH WAS REPLACED 1 YEAR AGO. ANY IDEAS?
CAN ANYONE TELL ME LOCATION FOR FUEL FILTER, FUEL PUMP AND FUEL PUMP RELAY? I ORDERED A SERVICE MANUAL FOR $120 BUCKS FROM THE DEALER. I WOULD APPRECIATE ANY HELP AT ALL.
You have a W211
But same issues apply.
Under 80k miles? Get the cats replaced free.
Over 80k splice in magnaflow universals.if not located in ca.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Have you replaced the cps crankshaft position sensor.If it failed you get no start,plenty of crank but no start![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
DIy on www.benzworld.org w210 diy section and on www.peachparts.com resource section diy articles.
Good luck
post codes when you got them.
ohlord
Good luck
ohlord
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
