Help with CEL light code
Old Dec 13, 2009 | 10:26 AM
ndiehm's Avatar
2001 E320
i had my CEL code pulled and it came back P0115, engine coolant temp circiut malfunction. i saw a post one time describing where it is located. i want to replace this but can't seem to find where it is. if anyone can help i'd appreciate it.
Old Dec 13, 2009 | 11:52 AM
ohlord's Avatar
Out sighting in a new scope on my
8mm Mauser.
so I can't take a picture but it is the sensor about 7 inches or so to the right of the camshaft position sensor that you can see sticking out of the passenger side cylinder head(also known as bank one)
You can probe test it with a multimeter resistance decrease exponentially with engine coolant temp increase.
Also make sure it is plugged in at the harness and that the connection is clean and clear of oil.
Lastly you might want to erase the code and see if it comes back.At times sensors like to throw a false code just to get your dander up
