Air Conditioning problems
Old Mar 11, 2003 | 01:25 PM
peeyoo's Avatar
2001 E320
I am in a hot climate (Texas) where the A/C does not cool the interior very quickly. Is there any way to maximize the effectiveness of the A/C or to enhance its performance?
When I set the A/C to blow out of the windshield and/or floor vents there is lots of "leakage" through the panel vents as well. Does anyone else experience this problem?
Is there any way to set the A/C so that the air blows out of the panel vents only (not the floor vents or windshield vents)?
Thank you.
Old Mar 11, 2003 | 01:47 PM
BenzE's Avatar
2006 E500 4matic Wagon
I am so jealous of your problem! I can only dream of the day when I can use my A/C again!
Anyway, make sure you keep the sunroof shade pulled shut to keep the sun out. Then, if you press the recirculator, you should get the coldest air possible. In my opinion, the auto fan settings cool (and heat) the car very well.
Stay cool...
Old Mar 12, 2003 | 03:47 AM
darkLCD's Avatar
Keep the temp at the lowest setting. Hit the Auto button. Then hit the Recirculate button. If your still having problems with the A/C not cooling fast enough or it is too weak, have the dealer check it out. My blower has been replaced once already for being too weak.
Old Mar 12, 2003 | 07:29 PM
dieseldriver's Avatar
97 E300
Also make sure the refrigerant is up to the right level.
Best way to check effeciency I found is to stick an accurate thermometer into one of the dash vents, put on recirc, max cooling. After running the engine and ac for 10 minutes the thermometer should read 54-57 F on an 75-80 F day. Just for info, a GM or Toyota will read mid to high forties. They are stronger.
Because I have a evaporator leak, I have to add a container of R22 every 4 months. I can tell when the AC effeciency goes down by the slow cooling.
Old Apr 11, 2003 | 04:38 AM
john.clarke's Avatar
Hi Peeyoo.......also in hot climate (Natal South Africa) .....E220 Sportline.
Follow other advice ....recirculate etc......but also keep the AC sensor in roof lamp cluster (behind small grill) free from dust / fluff etc....this greatly speeds up reaction to dial setting changes.
Good luck .....Tyke
Old Jul 9, 2004 | 01:04 AM
persianb28's Avatar
Were do you add the container of r22 at?
Old Jul 9, 2004 | 08:50 AM
EddieGTP's Avatar
Not a Benzer anymore
Diesel...
Is that written down anywhere? We get 57 degrees and GM/Toyota, etc. get 10 degrees cooler?
Hmm. Hmm. These hidden features.....
Old Jul 9, 2004 | 09:28 PM
suntubi's Avatar
e320 2000
Changing out R12
Hve any of you folks ever retrofitted away from the R12? I have an '89 300e and am facing that situation now. Good idea? Bad idea?
Old Jul 24, 2004 | 03:25 AM
JLLG's Avatar
1997 E320 2000 ML430
FWIW, It seems to me that recirculate should not be used until the interior car temperature is close to the outside temperature. For example, car interior temperatures can be well over 100 while exterior temperature is around 80. The AC should provide colder air at first by using air from outside versus the much warmer interior air.
