Newbie arrives with '99 4matic wagon and many questions
Only 95,000 miles and a full Carfax report showing a more or less uninterrupted history of dealer service ("for better or worse" I suppose I should say).
A few little problems to take care of, mostly minor cosmetic issues. But one mechanical symptom I thought I'd ask about: when my foot is on the gas pedal there is a slight whine, which seems to come from the front of the car. Take my foot off the gas, and the whine goes away.
My guess is that this is from the front differential. But you all will know more and better than I. Any thoughts?
the rear differential should have a drain plug and a fill plug (always open the fill plug first, then the drain plug).
also your car has a transfer case which uses automatic tranny fluid, but i'm not sure how you check the fluid there.
franasia and loubapache are forum members who have a 4-matic wagon, they are way more knowledgeable on the matter and hopefully will see your post.
It's a good idea no doubt to check the transfer case as well -- perhaps franasia and/or loubapache will advise me whether it's advisable replace the tranny fluid in the transfer case.
Thanks again. I'm loving this car.
Hello tmandel, congratulations for your new purchase and welcome to the forum.
I doubt the noise is coming from the front differential. It's very easy to replace its fluid though. There's a DIY by yours truly at benzworld on the stickies. I used a Mityvac vacuum gun and worked great.
Rear differential is easy as well. As far as the transfer case goes, I have yet to replace fluid on mine. The Mityvac would be the extractor to use here as well. Here's a link to an interesting thread:
http://www.benzworld.org/forums/w210...-question.html
Hope that helps,
Cheers
I owned a couple of Subaru SVX's (great car!) that had repeated wheel bearing problems; this doesn't have that 'round and round' sound I also associate w/ wheel bearings.
But, we'll see -- it'll be up on the lift today.
Looking at the car while on the lift was reassuring. A lot of good maintenance has been done and there are really no apparent problems. Looks like a new front driveshaft was fitted at one point, though I see no mention of this on my Carfax report.
We got the gas cap off -- that's good; now I can fill up! -- and I'll have to work with it until the Blau cap I ordered arrives next week. I'll have to be careful not to turn the current cap on too tight. Seems like a *really* silly problem for a car to have, I must say...
Franasia -- thanks for the link to the Benzworld thread, which was very helpful.
Something bad happened to that car before. That axle replacement might have had something to do with it. Far from being a 4Matic expert, but there's never been issues with front diffs reported in four years on these forums.OTH, do not trust Carfax that much. Actual dealer/indie service records is what you can really trust. Good luck with that repair and keep us posted.
Cheers
In any case, we'll swap out the front differential and take it from there.
As to what caused the differential problem, I'm clueless.
Cheers
I don't think I'll get to the bottom of this -- just replace the front diff and enjoy the car.
Hope you all have a nice holiday; you deserve it!
