Will these fit?
Old Jan 12, 2010 | 12:32 PM
4matico's Avatar
99 E320 4Matic Sedan
Will these fit?
So I found a set of AMG wheels and tires for sale. I was wondering if they would bolt right onto my E320 4matic?
I tried to get more info on them, but the person (older gentlmen) selling know nothing of offests, bolt patterns, tire sizes etc.. They were on a 2006 S-class 18'' Chrome AMG. Oh and he kept telling me they have 5 bolts! (haha) He won't take anymore photos, or get anymore info unless I go down and see him (2hrs away).
Before I drive all the way down to look at/purchase them, I want to know if they fit or not.
I think they should fit, just want a second opinion. Thanks for the help!
Here is the only bad photo of them.
Old Jan 12, 2010 | 01:22 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
I have S-Class wheels on my 98 but...
Standard was 16" and oversized option was 17" which is what I have. When you go to 18" you generally need a wider tire. The rims should bolt to your hubs with hybrid lug bolts; but the wider tires may rub. As you probably know, you need to mount tires which don't rub AND don't interfere with ASR/ESP AND give correct speed (or close).
There should be detailed specs engraved on the inside of the wheel such as size, ET and MB part no. If the seller is not willing to provide that information, then I'd pass on them.
You didn't ask but for my tastes chrome wheels don't look great on these older W210's which came stock with silver painted wheels. Just my opinion.
Good luck.
Old Jan 12, 2010 | 09:16 PM
4matico's Avatar
Thanks for the info! I am going to pass on them, too much hassle.
Is it only e430s and E55s that can run 18inch? Different setup than E320?
Best option for the E320 is to get 17inch wheels?
Old Jan 12, 2010 | 10:46 PM
ohlord's Avatar
You can run w210
e55 rims with the 35et rear and 31 et front and 275 and 235 on the front.
If you want to retain ride quality go with some 17's
www.dicsounttire.com and www.tirerack.com
sell some very nice 17 in rims sized to fit your car.
Also tons of tire and rim fitments info in the diy section on www.benzworld.org w210 section
BTW the offset on an S class is way off what you need.Good decision to pass.
