Service a/b checklist
Old Mar 16, 2003 | 03:07 PM
dallasdriver's Avatar
99 e430 Green
what is in each service?
Ok here is my problem, I bought a 99 e430 in july with 13k, and it had had the oil changed every 4500 miles, but I can find no records of an a/b service being done. I'm now at 20k, what service should I have done and what is in it? However, I know the owner had the window regulator fixed by the dealer at 10k and I'm guessing a service was preformed then.
Old Mar 17, 2003 | 03:06 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
I'd say you're due for a B-service. If a service was done at 10,000 miles when it was in for the window regulator, it was an A-service, so it needs a B-service now. If a service has never been done, it still needs a B-service because its too late for an A-service. Make sense? Also, since the car is 4 years old, I'd recommend replacing the coolant, brake fluid, and A/C dust filters if they've never been done.
Old Mar 17, 2003 | 11:04 AM
nguyensteve's Avatar
GLE53 Coupe
Model Years 1998 and Newer
Mercedes-Benz 10,000 Mile ("A") Service*
Lube and change engine oil and filter. Check and adjust all fluid levels.
Check belt condition and tension. Reset service indicator.
Check brakes and adjust parking brake. Check for fluid leaks.
Inspect all hoses and lines. Check all lights. Check steering fluid and undercarriage.
Replace climate control filter. Check climate control refrigerant and operation.
Check battery condition.
*Every 10,000 miles
Mercedes-Benz 20,000 ("B") Service*
Same as A service; includes tire rotation and balancing.
*Every 20,000 miles
The Mercedes-Benz brake system flush includes removal of the master cylinder
reservoir for cleaning. Drain Brake fluid. Check master cylinder and brake lines for leaks.
Replace fluid and bleed system.
Retailer recommended every 24 months.
Dust / Charcoal Filter Replacement
Reduces bad odors and removes pollutants from air entering passenger compartment.
Power Steering Service
Includes draining power steering fluid, inspection of pump and hoses for leaks,
replacement of power steering fluid and filter.
Check steering for freeplay as well as steering linkage for wear.
Adjust power steering belt.
Automatic Transmission Service
The automatic transmission service includes draining transmission fluid including
torque converter. Replace transmission filter and pan gasket.
Refill with factory recommended fluid. Check transmission mounts and linkages. ROAD TEST
The cooling system service includes pressure test of cooling system and cap.
Inspect hoses, freeze plugs and radiator for leaks and deterioration.
Check drive belts. Flush system including engine block and heater core.
Replace coolant and add antifreeze for 25° below zero.
Model Years Prior to 1998
Mercedes-Benz 7,500 Mile Service*(S Class Additional)
Change engine oil and filter, lubricate door, hood,
trunk hinges and latches and door and trunk seals,
clean and lubricate antenna mast,
check and correct fluid levels of engine cooling system,
automatic transmission, rear differential, level control,
brake system, power steering, battery and windshield washer reservoir,
lubricate engine throttle shafts and check for wear. Check rear engine stop.
Check tire pressure. ROAD TEST
*Every 7,500 miles
Mercedes-Benz 15,000 Mile Service*
Change engine oil and filter. Inspect for leaks and condition of all components,
lines and hoses on the engine, transmission, level control, steering system,
shock absorbers, fuel and brake systems. Inspect and adjust belts. Replace spark plugs,
clean air valves on applicable models.
Remove tires, rotate as needed and inspect brakes for wear.
Adjust emergency brake. Check all external lamps, horn, interior lights,
instrument panel indicators, and window function.
Check and service headlamp and windshield washer systems.
Lubricate engine throttle shafts and linkage and check for wear.
Lubricate door hinges and locks, replace wiper inserts. ROAD TEST
Wiper inserts S Class additional.
Mercedes-Benz 30,000 Mile Service*
All work described on the 15,000 mile service plus: Replace fuel filter,
air pump filter, service automatic transmission, change rear axle oil.
Check drive shaft flex discs for wear, check parking brake cables for free-play.
ROAD TEST
Wiper Inserts S Class, 5 Speed Auto Trans through '96 and V-12's Additional
Old Aug 19, 2006 | 12:29 PM
1stbenz00e55's Avatar
Exclamation ok don't laugh at me
.... my 2000 E55, just purchased, says Service Level A Exceeded By 200mi. Can this service, which seems to be, according to some posts, an in-depth oil change, be completed by my local Jiffy Lube? Also is the resetting of the service interval the same as resetting the oil service?.... Please Help as I do not want to do anything that will bring $$'Pain down the road.
RJ
Old Aug 19, 2006 | 12:58 PM
Air Marshall Eldritch's Avatar
John Deere
RJ
Please don't go to JL. You should have synthetic oil, and I wouldn't trust JL to put the correct stuff in there, or enough of it. Best to find a specialist.
But yes, the A and B services are essentially $350 oil changes. The services listed in the previous post are not included in the regular B service. They are additional options.
Old Aug 19, 2006 | 01:14 PM
Thank You Thank You
Mr RB.... Thanks For the Warning.... Ok just need to get my $$$ together.
This car is lowered with HN Springs but the ride is so harsh... any way to soften but still keep the "low"
