Help ...... "Light Defective" Hell......
Old Jan 28, 2010 | 02:36 PM
L398FRD's Avatar
Mercedes Estate TE 230
Ok I new here so excuse my stupidity!
1999 E320 4 door petrol .....
it was sent by a quack electrician who re arranged the rear lights beacuse he couldnt get one side to work..... (he connected the left side to the right side ....?).
Now I went to the MB dealer in my area who brought everything back to normal...... but......they say a sensor is damaged ... the one that give you the "light Defective" message on the dashboard....
What is it ?, where is it ? and can I get it and replace it without having to pay them another arm and leg?
I LuV My TE....
Old Feb 3, 2010 | 10:30 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
I LuV My TE....
It's might be your brake light switch located above your brake pedal. Not that expensive and very easy to replace.
http://www.autohausaz.com/search/pro...Light%20Switch
Old Feb 3, 2010 | 08:48 PM
Fabio D's Avatar
210 55
Nope.. the sensors to determine a faulty bulb are integrated in the light switch fuse box, (is a black block with 10 +/- fuses & the light switch integrated) you can chech the fuses via opening driver door & removing the cover on the side dash. this fusebox have integrated the blown bulb sensors, we need to replace some of that in our workshop. i recommend you buy some via ebay:
Here u go:
http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
Fabio Daniel
Old Feb 4, 2010 | 10:31 AM
L398FRD's Avatar
thank you
that's the answer..... thanks alot
