So I picked up an OBDII scanner today...(help with codes)
1998 e320
FIgured it will come in handy lol.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I started by clearing out all codes, then driving until the check engine light comes on again. After about 20 miles it came back on. So i hooked my new toy up & the following are what came on:
P0170
fuel trim malfunction (bank1)
P0173
fuel trim malfunction (bank2)
I did notice today a couple of times when i pressed the gas to accelerate from a dead stop the car seemed to hesitate or bog down for a moment, then it would take off like normal.
Any ideas?
TIA
UPDATE: I did a search on these error codes & ive seen a few references to the MAF sensor. When i first got the car I took it by Wal-Mart to get them to condition the headlights (remove the yellow haze) & install a couple of bulbs. The reason for this is that about 3 weeks ago I broke my kneecap & I have a lot of trouble bending & such, on crutches & all. they had to remove the breather for access to one of the bulbs, & I just realized that I didnt get any check engine light action until afterwards. is it possible that those idiots did something?
P0170
P0173
Any ideas?
TIA
W210 E430
I would check to make sure the MAFS is plugged in all the way, and that the intake and breather hoses are all securely connected. Also check the air box to make sure they didn't leave any presents in there. Wal Mart "technicians" are usually not of the same caliber as any other automotive technicians and are typically more prone to screw up something.
Any air
getting into the intake after the MAF will cause maf codes.
Fix the hose.First.
After that the problem should resolve.
If not and there is no air getting in unmetered you need to get a real oem maf from www.autohausaz.com
takes 5 minutes to install and you can do it one kneeeed![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Next time follow the diy for polishing lenses on www.benzworld.org w210 section and do a better job yourself after you are all healed up
Fix the hose.First.
