Touch up Paint
Old Feb 19, 2010 | 09:51 AM
Delux2d's Avatar
00 S430 & 02 Suzuki 750 Katana
Touch up Paint
My car has some little dings and scratches.. what can I use to touch up the paint without getting the whole car repainted?
Old Feb 19, 2010 | 10:40 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
The MB dealers have touchup kits (about $25). They match pretty well for small chips, door edges etc. Mine had two bottles -- paint and clearcoat.
Good luck.
Old Feb 19, 2010 | 11:29 AM
E-420's Avatar
97 E-420
go with Dr.Colorchip. Much better for touchup of road rash etc. than factory or other touch up paints. Used it on three different vehicles (Silverado- Green, E-420 "royal indigo" and Honda "Champange") Doesn't leave "pimples' like most touch up paint, and if you goof, easy to remove and try again.
Old Feb 19, 2010 | 12:37 PM
Delux2d's Avatar
Thanks you guys ROCK!!!
Old Feb 20, 2010 | 06:16 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
I have used Autosharp Pen
with great results on small chips and scratches. Color matching is excellent:
http://www.autosharppen.com/
Hope it helps,
Cheers
Old Feb 20, 2010 | 06:32 PM
BigBoss's Avatar
2002 Mercedes Benz E320
I washed my car just the other day and was shocked to see how many rock chips there was. I couldn't really see them with all the dirt on the car from the dirty streets. How hard is it to match Brilliant Silver?
Old Feb 20, 2010 | 07:51 PM
RichardM98's Avatar
I have #744 too and found the dealer kit to work well. After paint has fully cured, rub out with polishing compound and then a coat of clear coat repair. Almost invisible.
The other advantage is that the manufacturer knows the paint chemistry and can spec a repair coating to best match for both bonding and color.
Good luck.
Old Feb 28, 2010 | 05:16 PM
Delux2d's Avatar
What Color is this ?
Is this AZURE BLUE MET or CAPRI BLUE?
<TABLE cellPadding=4 width=425><TBODY><TR><TD align=middle></TD></TR></TBODY></TABLE>
Old Feb 28, 2010 | 06:40 PM
raymond g-'s Avatar
99 E320
the metal plate with the numerical color code is in the engine compartment
Old Feb 28, 2010 | 07:17 PM
Fabio D's Avatar
210 55
i think thats 189 emerald blue same as mine! Check the plate in the engine compartment
Fabio Daniel
Old Feb 28, 2010 | 09:09 PM
RichardM98's Avatar
Yes, the metal plate will tell you. However, there are about thirty 3 digit numbers with no labels like 'paint code' so unless you already know the number is will not be easy to find.
Here are some other possibilities -
1) If you have a service invoice from dealer check for a little box labeled color. Usually two codes like 744/208. First is exterior paint second is interior.
2) Plug your VIN into this site. Color codes are lines 11 and 12
http://old.mbclub.ru/mb/vin/?lng=eng
3) Look for the option card which came with your car when new. It is sometimes glued into the back of the owners manual or glued on the inside of a removable panel in the rear storage area.
4) You can also join epc net (it's free if you run windows and live in US). Once a member, find the menu option for the 'data card' and run it.
Good luck.
Old Mar 3, 2010 | 08:51 AM
e24kgold's Avatar
2005 c230k ss, 2005 Land Rover LR3, 2006 Honda S2000
Dr. color chip by far
Old Mar 3, 2010 | 06:56 PM
RichardM98's Avatar
For anyone who's interested I took a picture of the code plate on the radiator support. I highlighted the interior/paint codes for reference.
On mine 208 is interior and 744 is exterior paint.
