Dealer suggested the following:
Not trying to get in the last word, honest. But you might PM ohlord when you're ready. I think he has a good source for the universals that work AND pass state smog tests.
2023 GLC 300 4MATIC
just looked at my invoice. they suggested changing the fuel filter not the fuel pump. I think he said around $350 so I assumed that was for a fuel pump. $350 to change the filter?
Yeah, dealers can be high. A Mahle or Bosch filter (OEM) is about $35-$40 from a 3rd party supplier like autohausaz.
Haven't done mine but speaking from what I've read: Remove cover panel under rocker just in front of left rear wheel. Pinch off supply lines with some form of clamp, undo hose clamps (4), exchange filter, tighten new hose clamps, release clamps on supply lines and replace cover. Maybe 1/2 hr.
anyways, $350 is still high. My dealership, the price is about $120 for a filter, plus 4 hose clamps. about an hour labor. all in all, that price is still high by about $100-150
#32
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
Are you getting misfiring codes??? If not I'd tell the stealership to "Octothorpe Silicone" == # Si == pound sand....
#33
It changes all the time
Jeeesh,
Back to the original question at last. $350 for a filter change is steep, but check to see if it doesn't require some new up date mod like the early MLs. 100K is when I would change the plugs, and I wouldn't go much further to reduce the risk of the plugs seizing in the heads. Anyone replacing their own plugs had best use anti seize on the threads or getting them out next time may require pulling the heads.
#34
