ABS BAS ESP ALERTS
Old Mar 2, 2010 | 06:42 PM
n00be320's Avatar
01 e320 4matic
ABS BAS ESP ALERTS
01 E320 4MATIC
yesterday alerts came on for these 3 malfunctions. Today came on again while driving home. I reset the relay for abs and started up again malfunction went away. Where can i start to diagnose further? Is this a common genie?
Old Mar 2, 2010 | 10:41 PM
armaniE55's Avatar
2012 CLS63 AMG
Thumbs up
Originally Posted by n00be320
01 E320 4MATIC
Hi there,
I can't comment on 4Matic but I would assume/guess it's your brake light switch. Do a search for my name I just replaced mine recently. Easy DIY
Armani
Old Mar 24, 2010 | 06:39 PM
N7OGP's Avatar
W639 2011
I had the same problem last year, but mine was the live feed to the brake light switch, if it is the BLS it's only a 10 minute job.
Old Mar 26, 2010 | 07:07 AM
Hi Fi's Avatar
2001 Black E320 4Matic -2002 Silver E 320 4Matic Wagon
If I were you I wold hange it right away.
Mine had came up and went away,so I bought the swith and was in no rush to change it.
My wife went to the grocery store then the car didn't go into drive and couldn't leave the parking.
I had to get the switch changed in the parking lot.
I wouldn't neglect that for a 20.00$ part.
Old Mar 26, 2010 | 05:23 PM
Greg Phipps's Avatar
2000 E430
FYI - When the three lights come on, you lose your brake lights also.
I changed the brake light switch today ($28 part at MB dealer) - solved the three warning lights, got my brake lights back, and I now can shift out of park without the "pen in the emergency release" tab.
Old Mar 26, 2010 | 05:54 PM
mi benz's Avatar
98 E300
Originally Posted by Greg Phipps
FYI - When the three lights come on, you lose your brake lights also...
This isn't the case with mine. It could certainly happen with a bad brake light switch, though.
Old Apr 4, 2010 | 04:22 PM
oldmbz's Avatar
e420
There appears to be a significant distinction between just having the warning lights go off as opposed to the throttle being limited to the "limp home mode" Unfortunately, I am suffering through the latter affliction which appears to be independent of the simple BLS or NSS replacements that have been described extensively in recent threads. My car still goes into LHM on cold starts which after multiple restarts returns to normal throttle response until the next morning cold start. I have already replaced the ETA and now am looking for a reasonably priced control module for the ASR/ET/CC.
I wish it were only the $20 BLS!
Old Apr 17, 2010 | 08:21 PM
mi benz's Avatar
98 E300
Just wanted to post the solution to my ESP/ABS/BAS problem.
After trying the brake light switch to no avail, I had the codes scanned at a local indy shop and the lateral acceleration sensor had thrown a code. This module is part of the ESP system and is located under the carpet beneath the driver's seat. Believe it or not Mercedes wants > $2K for this module! I found it on a German used parts website for < 50 Euros I finally got it replaced today and the annoying beeps and lights are gone
It's MB part number 000 542 65 18.
good luck!
Old Apr 24, 2010 | 06:48 PM
mr-flyer's Avatar
E55, S65, C63, SLK55K4
mi benz... what was the parts website you ordered it from?
Old Apr 24, 2010 | 08:11 PM
n00be320's Avatar
01 e320 4matic
http://www.autohausaz.com/
Old Apr 25, 2010 | 08:18 AM
mi benz's Avatar
98 E300
looks like they're back in stock:
http://www.fr-210.de/Mercedes-W210-S...sor-0005426518
good luck!
Old May 2, 2010 | 08:57 PM
UstadJee's Avatar
2005 e320 4m
Brake light switch. Easy to replace. Under the driver's side dash, above the brake pedal. OEM price is $15.00 or so.
Old Nov 20, 2010 | 05:13 AM
1phoenix's Avatar
2002 e320
I have the 3 lights on problem. Tried the steering wheel fix to no avail. Would it still be the BLS if brake lights are working properly ?
Old Nov 20, 2010 | 05:15 AM
1phoenix's Avatar
2002 e320
