Headlight Bulb Replacement
Old Mar 17, 2010 | 05:30 PM
TX E430's Avatar
2001 E 430
I am replacing my headlight bulbs (brights) does the whol assemble come out towards the front of the car and then you pull out the bulb and replace it with the new one? the compartment is pretty cramped and I am not seeing that there will be enough room to remove the old bulb from the rear.
Thanks for yopur help.
Old Mar 17, 2010 | 07:43 PM
RobertG's Avatar
things with and without wheels
head light bulb comes out from the inside, 2 screws hold it in place.
if you want to remove the whole head light assembly, the front bumper has to come off first.
Old Mar 18, 2010 | 08:10 AM
Hi Fi's Avatar
2001 Black E320 4Matic -2002 Silver E 320 4Matic Wagon
Speaking of bulb replacement.
I need to change my foglight bulb on my wagon.
What is the trick.
It seems I have to go under the car to change the bulb?
Old Mar 18, 2010 | 10:46 AM
okc329's Avatar
1997 E320 (silver/black)
If I remember correctly ...
there is a screw or two undr there. Loosen thos and the assembly swings down giving you access to the bulb.
Old Mar 18, 2010 | 11:54 AM
E92-Lighting's Avatar
Former Vendor of MBWorld
BBS LM's 18's + Kics
we are fully stocked with all fog light bulbs and HID's for all car models
Old Mar 21, 2010 | 02:03 AM
davezaristo's Avatar
16 GLE400, 16 eGolf, 15 M3, 13 328i, 06 S430, 98 E320
just replace it with a HID kit..I've paid $30 for it and it was super easy to install...took me 15mins and you can stuff the ballast and all the wiring inside the headlight cover...
