wheel balance
Old Mar 24, 2003 | 12:24 PM
2quik's Avatar
wheel balance
My rims and tires came mounted and prebalanced from tirerack, Carlsson 2/5 , dunlop 9000. But i have a very slight shake in my steering wheel. Its very slight , but its there at 60 mph. I checked tire pressure and its 32 front 33 rear. SHould i get rebalanced or is it just the road feel . But it never fails at 60 mph i get a slight shake in my steering. Any suggestions? Luke?
Old Mar 24, 2003 | 07:08 PM
bhazzard's Avatar
97,e320
Go get it checked out early for warranty issues. What size rim did you go to? I know when I went to 19" AMG's as with all larger diameter rims the road get's a little sensitive......Good luck!
Old Mar 24, 2003 | 09:55 PM
spoothead's Avatar
2000 E430
I think it might be a wheel balance issue since it occurs at a certain speed. Sometimes the balance on wheels and tires can change slightly after being driven. It has happened to me a couple of times, but mostly the balance done at the time of mounting works fine. Just my $.02.
