where is the speed sensor located?
Old Apr 4, 2010 | 03:53 PM
benznyc's Avatar
ml/e420/others
Exclamation where is the speed sensor located?
im stuck in limp mode and got the car computer checked at pepboys and its the speed sensor..
anyone has a d.iy/location /pics of this ??
Old Apr 4, 2010 | 04:00 PM
MyBigBenz's Avatar
SLK
According to this page:
http://www.racepages.com/products/?D...43+11210&Nty=1
It's located at the rear passenger. I'm assuming this correct, so maybe there's a start? Look for it somewhere around the axle, bearings, etc.
Old Apr 5, 2010 | 10:32 AM
benznyc's Avatar
ml/e420/others
cant find? anyone has a write up or pics/diy?
thanks on the help..hope its not a big job.
Old Apr 5, 2010 | 11:58 AM
tirona's Avatar
1997 s320, 1997 e320
what's the error code, p0715? if the code is in the p07xx range than it's the transmission speed sensors located in the conductor plate. pretty common failure for early 722.6 tranny. did you read reply i made on benzworld? read the tranny stickies on bw w210 section, loubapache has a detailed protocol for replacing the conductor plate. price is around $200, you need to drain the fluid, drop the pan, and replace the conductor plate. http://www.benzworld.org/forums/w210...ml#post3538903
if car drives fine after restarting or erasing error code, than you can drive the car for now, and if problem reappears then you need to replace the conductor plate. what was the error code? is car still in limp mode?
Old Apr 13, 2010 | 12:42 AM
hassmakki's Avatar
Mercedes E55
Tirona is right, there is no single vehicle speed sensor for your vehicle. Most likely its with your transmission(input/output shaft speed sensors). That link shows a abs sensor for one wheel there are four of those on your vehicle, not gonna fix you problem. Chheck back with codes.
