'02 E320 won't start.
Old Apr 6, 2010 | 05:04 PM
BigBoss's Avatar
2002 Mercedes Benz E320
I just went outside to move my car so my dad could get to his and my car wouldn't start. I stick the key in, close the door and turn it so it cranks and it kept cranking for like 5 seconds before I shut it off. I repeat about 3 times and still won't start. I get out and lock the car and unlock it and get back in and try again and this time it turns on. Check engine light is on.
It all runs fine I just reversed out and turned around and stuff and pulled back into my driveway. I shut it off and it turned back on with no problem. Did that about twice and it was fine. No trouble but the CEL is still on. What's the deal?
Old Apr 6, 2010 | 05:20 PM
AMGSpartan's Avatar
2008 GL320 CDI, 2007 E320, 2005 Passat TDI
If it has a crankshaft position sensor, I'd replace it.
/Sparticus
Old Apr 6, 2010 | 09:01 PM
BigBoss's Avatar
You were right. I suspected it and I hooked it up to a scanner and came out with "P0339 Crankshaft Position Sensor A Circuit Intermittent".
I can't find the part on autohausaz.
Old Apr 6, 2010 | 09:55 PM
AMGSpartan's Avatar
I bought mine at allmercedes.com
I removed mine with a 1/4 inch socket on a long extension. The proper way would be to use a T-8 SOCKET which I didn't know existed until I had the CPS bolt in my hand. Duh... I've got a lot to learn. Doing the job on a COLD engine is much easier too.
/S
Old Apr 6, 2010 | 10:17 PM
BigBoss's Avatar
Whats the difference between the sender and the sensor? I'm confused because there's like 4 different things.
Old Apr 7, 2010 | 09:53 AM
AMGSpartan's Avatar
I don't know why allmercedes.com does that. If you check the part number that comes up for "crankshaft position sensor" and "position sender-crankshaft" they are the SAME. I can see on their ordering page right now they list the SAME part with at least 4 different names in the drop down menu when I searched for "crankshaft". Each time you clik on that part, though, you will see it brings up the same part number (part #003 153 28 28). My car took the same part.
Some of their drop down menus with parts listed will actually be 2 or 3 different parts but they will list each part with 4 or more different names therefore their "list" appears to be very extensive while it really isn't.
/S
