1999 E320 Headlight Bulb Replacement
Old Apr 8, 2010 | 07:30 PM
skipsantos's Avatar
2008 E350 Sport/2016 E350
I have searched the site as well as others trying to get basic info regarding the replacement of a headlight bulb for a 1999 E320, but found nothing.
Does anyone have a recommendation as to which brand of bulb to purchase (H7 55W)? All other posts seemed not to be related to replacement of a standard bulb.
Any comments or recommendations as to quality of the replacement buld would be appreciated.
Old Apr 9, 2010 | 11:22 AM
kevinC's Avatar
I picked up a GE H7/55 at WalMart for about $10. I've also seen the H7 by Phillips and Osram. All good. Some say replace in pairs but I did not and lighting was even. You can also check danielsternlighting.com for info in a 65W H7 which some on benzworld.org recommend.
Old Apr 9, 2010 | 12:13 PM
skipsantos's Avatar
Thanks for the recommendation.
Old Apr 10, 2010 | 11:48 AM
skipsantos's Avatar
I bought the GE H7/55W at Walmart @$8. Quick and easy and replacement.
Old Apr 11, 2010 | 11:04 AM
JayBar's Avatar
'97 Mercedes-Benz E420
I upgraded to the Osram Rallye 65w Ultra High Output H7 from Candlepower Inc., and also refinishing my headlight lenses. The difference is amazing.
Old Jun 8, 2014 | 07:40 PM
dawgfood's Avatar
M.Benz 1999 E320
Changed the bulb, but no light still
I just bought my 1999 E320 and the left.... I dunno what you call it to be honest, when you turn your lights on the first click turns on the inside lights... my left one is out, if i turn it again then the other 2 come on as well but the left inside light stays off. I've tried 2 different bulbs to no avail.
Any suggestions?
Thank you in advance, I appreciate any help.
Old Jun 8, 2014 | 11:02 PM
raymond g-'s Avatar
99 E320
Any suggestions?
use SEARCH function is good option, too
