flashing lights E200
Old Apr 21, 2010 | 11:45 AM
johnny zam's Avatar
mercedes e200 1996
i have E200 1996,the problem is that every single time if i unlock the car car with or without using remote key,light on the door and both green and red light start flashing and car will not start but if i disconnect and then reconnect the main cable of the batry then lock unlock car wil start and drives ok if i take out the key from the ignition the car will not start for the next time unless i do that again. i pic and drop my childrens from school i do this every morning and afternoon canot spend money going to the MB dealers.
can any one help me
Old Apr 21, 2010 | 07:26 PM
ohlord's Avatar
Most likely
a problem with the pse.
Have you inspected it for loose lines or standing water?
If not that then you need to find an independent shop that has a star diagnostic machine and have them run the diagnostics.
Old Apr 22, 2010 | 05:37 AM
johnny zam's Avatar
mercedes e200 1996
yes i have tried with the local guy but his diagnostic machine could not find the fault,there are no loose lines or standing water anywhere in the car.thank you.
Old Apr 22, 2010 | 08:14 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
pull up the rear seat and check yourself for any water.. If you find no water, unplug the PSE electrical connectors and check for green colored corrosion on the connectors or inside the pump. Your local guy may just not know where to look..
Old Apr 22, 2010 | 09:25 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
SDS (Star Diagnostic System) is mostly at the dealer or a very well heeled indy. Since most of the interface is proprietary, have the car scanned with the 'real McCoy'. Although, as mentioned, check the battery/PSE area and wiring yourself if you haven't done so.
Good luck.
Old Apr 23, 2010 | 09:39 AM
johnny zam's Avatar
mercedes e200 1996
i checked the PSE its dry and its clean and no corrosion
Old Apr 23, 2010 | 09:49 AM
johnny zam's Avatar
mercedes e200 1996
Good luck.
thank you for you kind advise but the strange thing is that why my cars engine starts after unplug an plug it back on the battery.is it that some sort of memory resets the imobeliser or alaram may be.i have checked the palaces battery/PSE that seems clean and no corrosion. thank you
Old Apr 23, 2010 | 11:00 AM
RichardM98's Avatar
Your car's electronics stores values for several things -- some but not all of them are erased when you disconnect the battery. Sort of like a reboot on your PC. Of course, if the problem still exists the faults are reestablished.
Good luck.
