Injection nozzle broken, confused in numbers
w210 3.2 CDI
Good day Dear MB Drivers !
Finished nozzle in 1st cylinder, need to repair it or to buy new![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Original detail number is A 613 070 05 87.
I Have new nozzle original mb part but it's from G-class - 2.7 CDI engine with number:
А 612 070 05 87 - will this nozzle fit my 3.2 CDI Engine ?![Sadwavey](https://mbworld.org/forums/images/smilies/sadwavey.gif)
I see the difference only in first 3 values - as i know it's engine variety 613 612...
what you could do is contact a local MB dealer and have them check to see if the part number you are replacing is possibly superseded by the other part number..
Seeing as how they are from 2 different sized CDI engines, I doubt they are interchangeable though.
'99 E430, '05 ML500, '15 GLK350
Schau Dir das mal an:
http://cgi.ebay.de/Einspritzduese-In...item230372dc42
As far as the other part number, it may work but I would guess not. If it has the same Bosch part number (above the MB number) then maybe, but usually MB doesn't create new parts when they can carry over an old one.
