Cup Holder Hooks cover
I was wondering how you remove the whole plastic housing inside the cup holder where the Hooks hold the cover.
I know how to remove the cup holder, but the hook are attached to a plastic housing.
My hooks inside wiggle and are loose like broken or not attached, which means the cover doesnt rebound or open.
I would like to remove it and replace it somehow, Not sure how to do this or find a replacement part for it or somehow fix the hooks in place.
Please help
yes please send me some instructions.
Also yes i may be interested if the price is good and the job is fairly easy to handle and worth it.
Let me know. You have the housing? plus the cup holder?
1 - Remove the black rectangular trim around the gearshift. Just pry up carefully around the edges with some sort of non-marring tool like your fingernails. The tabs which hold it are pretty long so just keep working it up on all 4 corners until it's out.
2 - Loosen the burlwood trim w/switches by opening the door on the cupholder and lift at the back edge and front edge. It just pops out. Disconnect the 3 electrical connectors. Set panel aside.
3 - Remove the two philips screws at the front near ash tray. Lift the two metal legs which were being held by the screws up a little to facilitate removal of console.
4 - Remove the two philips screws just behind the gearshift.
5 - Open the center console storage cover. In the bottom remove the felt pad. Remove the two philips screws hidden under the pad.
6 - From the back seat, remove the panel just below the air nozzle. It just pries off.
7 - Lift console up and a little back until its free.
8 - When you turn it over you'll see the two screws which hold the cupholder compartment in place.
After doing it a couple of times you'll be able to remove the console in less time than it took me to write this.
If after checking, you are interested in any parts I have PM me.
See here:
https://mbworld.org/forums/interior-...arts-gray.html
The cupholder compartment is installed in a console I have but I would consider pulling it and selling it separately if you are interested.
Good luck.
So the part that i am talking about is the compartment? or " housing" that has the hooks. that's installed in your console already.
Alright how much do you want for that part, and cup holder each.
