Coolant Flush E320 w210
Old Apr 24, 2010 | 08:30 PM
n00be320's Avatar
01 e320 4matic
Just flushed my coolant with mb genuine and distilled water 50/50 mix
I could not find the drain plug on the engine block, even though it is mentioned in the owners manual w/o any pics or descriptions.
So i remove the lower hose and also the petcock on the radiator to drain.
Also replaced the thermostat with a new one from autohauz.
Does anyone have a pic of where that drain plug is and next time is it worth the hassle?
thnx.
Old Apr 24, 2010 | 08:54 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
On the M112 and M113 engines there isn't one. You drain at the radiator.
Old Apr 24, 2010 | 10:00 PM
n00be320's Avatar
01 e320 4matic
Ok , thanks but confused as to why the owners manual on page 262 talks about a drain plug for the 2001 e320 4matic.
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td valign="top" width="100">
</td> <td valign="top">
</td> <td align="right" valign="top" width="70">
</td></tr></tbody></table>
Old Apr 25, 2010 | 03:22 AM
Lancelot's Avatar
'01 W210 E320 CDI
When completely draining and flushing the cooling system I would also replace the thermostat. It's cheap and prevents cooling problems and keeps the heater working properly during winter. If I rememer correctly a thermostat with new gasket costs € 14.- at the dealer. I do this every two years.
Old Apr 25, 2010 | 09:38 AM
Hirnbeiss's Avatar
Mine says that too (on p.109) on the engine right side, but from what I see in my repair manual, and going on memory from when I last looked, I haven't seen it. If there is one, no one uses it because you get the entire 2 gallons out from the radiator draincock.
Old Oct 29, 2011 | 03:13 PM
PhillyBenzGuy's Avatar
e 320
thanks alot is there pics or a noob youtube video of this also my gaurd is so tattered how do i get it off? is there a diagram for that? my 210 is 97
Old Oct 30, 2011 | 11:46 AM
vinceC's Avatar
2014 ML350 4Matic
There is a drain fitting on the right side of the block. It looks like a male hose fitting. There is no external hex, just an internal hex for a hex socket. I have never gotten more than a few drops out of the block drain fitting after I drained the radiator through the drain plug, so I no longer try to use the block drain fitting. I posted a detailed writeup here a number of years ago about this.
