help my cluster is not working (w210) 96
Old May 11, 2010 | 02:40 AM
junior khan786's Avatar
w210 e230 96
Cool help my cluster is not working (w210) 96
guys got any ideas as to how i can get my cluster working w210 96 mod. speedo, rev meter fuel and temp gages all dead the revs just vibrate up an down but sumtimes the whole thing works i dont get it
Old May 11, 2010 | 05:07 PM
Lancelot's Avatar
'01 W210 E320 CDI
Sounds like a bad connection somewhere or a cracked contact on- or in the cluster. Did you remove the unit to checks things out?
Old May 12, 2010 | 12:21 PM
gatonls's Avatar
97 E320, 04 C230K, 06 R500
Ya, mine did the same.........had to get a new one.
Old May 12, 2010 | 01:08 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
If everything is off/on then it sounds like a short to ground someplace. You might try disconnecting the battery (for 15min) and while it's disconnected, pull the cluster and reseat the connectors. It's a long shot but doesn't cost much.
Be sure you have the radio code before disconnecting power.
