AMG W210 fog lights
Old May 27, 2010 | 11:07 PM
equipmentman's Avatar
e36 mercedes
Angry AMG W210 fog lights
can someone please tell me where I can buy a pair of HID AMG fog lights to fit 96 AMG W210 ?
Old May 28, 2010 | 02:07 AM
BigBoss's Avatar
2002 Mercedes Benz E320
ddmtuning. com
Old May 30, 2010 | 02:22 PM
e36 mercedes
ddm tuning
Checked with these folks on the HID fog lamps for W210 AMG but they have nothing . Any other suggestions ??
Old May 30, 2010 | 02:24 PM
e36 mercedes
What mods can I do for my E36 AMG in W210 car , 1997 ?? Would love to be able to just smokw those tires off the line .
Old May 30, 2010 | 10:20 PM
BigBoss's Avatar
You just select which type of bulb you have for fogs which should be H1. What are you trying to do?
Old May 30, 2010 | 11:51 PM
e36 mercedes
FOG LIGHTS FOR AMG W210
My lamps are all cloudy so I want to change them to a newer & cleaner look , makes sense ?
Old May 31, 2010 | 02:26 AM
BigBoss's Avatar
So you're looking for the fog light lens? I'm sure you can find online on ebay or some other seller. Maybe a local dealer?
Old Aug 14, 2010 | 11:44 AM
e36 mercedes
Big Boss
hey Big Boss ,
Have tried just about everytwhere for the AMG W210 fog lamps and no one seems to have anything .Looks like I need to go to dealer , but really wanted them in crystal . Any help from anyone would really be appreciated
Old Aug 15, 2010 | 02:21 PM
rschultz101's Avatar
W210 E300 turbo diesel
also looking at getting the sand-blasted ones a fresh look.
there are a couple of thoughts I ran into,....
the stock ones are hella, and have lines in the lens,
they are very good at spreading the light.
- to replace the lens only, but that would not change the looks,...
- to get projectors ones, but they would look lost, and the light output, would not be as good, especially to the side
- clear or crystal ones, look good, but hella has much better reflector
also with clear, I'am afraid , it will cause more glare for oncoming traffic
- cheap projectors and HID, be to much glare for sure
- to get the crystal ones, and just use the lens, but the lens is part of the reflector, for beam pattern,...
- to go with hella micro DE, be more work, than a like
- LED, be nice if there was on option, to have the newer look LEDS,
and use them for daylight driving, and looks.
but to be practical, they would need to be powerful and dot/sae approved
think hella has some, but $400 plus install, is a little steep for me,...
Old Aug 16, 2010 | 11:17 AM
e36 mercedes
AMG FOG LAMPS
Will give HELLA a try , thanks a million .
Old Aug 16, 2010 | 03:00 PM
raymond g-'s Avatar
99 E320
one thing to be aware of if you attempt to replace a fluted lens with a
crystal clear one:
the fluted lens helps camoflage a reflector which is aesthetically unsightly.
it can, because the view through the flutes is distorted. if the flutes
become clear, you see an ugly reflector....kinda like jessica simpson nekked
and no make up. so just be aware.
Old Aug 17, 2010 | 11:41 AM
mike430sport's Avatar
2000 E430 Sport
HID FOGLIGHTS
I just got brand new AMG fog lights for my 2000 and I want to hook up HID's to them. I bought the Hid's at a local shop $60. AMG uses "H3" not H1. It looks like I am going to have to splice wires together. The factory plug, female end on the fog light is smaller. The HID kit has a larger male plug, same design and will not fit. Maybe they sell an adapter???? Need to find one before I decide to cut wires.............
Old Aug 17, 2010 | 12:24 PM
e36 mercedes
These are what my fog lamps look like :
Old Aug 17, 2010 | 12:32 PM
2000 E430 Sport
NO pic.........
Old Aug 17, 2010 | 12:59 PM
HID's in fog lights be too much,
- if they are not designed for it, might melt
- too much glare, especially when wet
- ticket magnet,...
if you take a look at the fog lights, you'll see pretty much all decent ones,
have a bulb shield, ether build in or in the bulb.
also, if it has a bulb shield build in, the HID bulb is longer and won't fit.
Old Aug 18, 2010 | 11:14 AM
2000 E430 Sport
Actually in another board HID's were tested and are fine in the fogs. There is a shield built in on the AMG fogs. To fit the larger bulb you have to slightly bend the shield back to fit the light in. Here is the link
http://www.benzworld.org/forums/test...99e430s-2.html
Old Aug 24, 2010 | 11:23 PM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
I just installed 5000k h3 hid's in my e55 . They look great . I actually pushed the reflector a little too much in on one side so i kind of shines a little bright but they look beautiful and were plug and play . But i had to splice the wires because i didn't want to drill a whole into plastic cover so spliced and ran through the little slot on the cover and hooked them up .. One thing . The h3 bulb used ground wire that connects directly into bulb housing . On hid you have to disconnect and run directly to harness might seem tricky . Also one of my positive wires didnt have plastic protoector end so when i buttoned it all up shoved wires into the housing area popped a fuse .. will post a pic of how they look soon as i charge my battery up .
I bought these lights for $40 they list $43 but if you offer $40 they will accept very fast shipped have bought couple times from them
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
i have no affilliation other then im a customer of theirs
They are direct plug and play no seperate power harness relay ..
They are slim digital ballast kind of a ***** because i was working through little whole of the plastic under cover but still managed to find a place . But for $40 bucks you can't go wrong hell my PIAA's cost me 60 for some wanna be hid look bulb new i shoulda gone str8 with hid's FTW
