Dashboard Temp. Sensor?
Old Jun 17, 2010 | 11:21 AM
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
Hey,
Last night i was driving home and the temperature indicator in the dashboard went crazy!
At first the external temp. indicator was in 17°C and after 30 seconds went to 0.6°C, then 0.5°C (pic taken) and after that oscilates between -5°C and +25°C.
Replacement part? Anyone?
Old Jun 17, 2010 | 12:15 PM
saintz's Avatar
GL450
It's in the front bumper, near the ground, left side (driver side in US, passenger side in UK). You should be able to see it poking through, it looks like a little rubber tip pointing forward. You can find the replacement at parts.com, autohausaz.com, your dealer, etc. Should be about $15.
Old Jun 17, 2010 | 12:25 PM
kbad's Avatar
2001 E320 - RIP
check driver side housing (to the left of the fog light - flat plastic with a protruding point - it is the temp sensor) to see if the sensor has been bumped out/pushed in! ...also check connector and make sure it makes a clean connection...it may not be bad.... if it is, pick one up here... http://www.autohausaz.com/search/pro...ature%20Sensor
Old Jun 17, 2010 | 03:39 PM
paqueras's Avatar
Thanks to Kbad & Saintz!
I will check this out this afternoon as soon im back from work.
Old Jun 20, 2010 | 08:03 PM
paqueras's Avatar
Problem solved!
I just pushed it a little and thats it!
Old Jun 20, 2010 | 08:46 PM
kbad's Avatar
2001 E320 - RIP
right on!
